Duct fan system for HB
Is this any good?---http://www.helihobby.com/html/hummingbird_upgrades.html
If any of you have it, how did you install it on your hummingbird (what did you do extra, did you use ties, glue, etc.) thanks |
RE: Duct fan system for HB
I too use the Gws edf 50 $15 and it works awesome!;)
Tell me how much better it is than the stock system.-(0 percent to 100 percent)
Also, does everything work the same on it, I mean turning left and right (does it turn better?) Finally, can you tell me how to install it |
10000% better
the stock setup sucks the first upgrade everyone should make |
I heard from the expert guy (the one I see on almost every thread) that they are heavy and not good for normal flying?
Is this so? Also-Which Gws Edf 50 did you get, there were many wit different type blades. Can you give me many pics of your fan system-installed (like 5 from diff. angles) Thanks |
1 Attachment(s)
Here's one that is pretty straight forward. What kind of tx do you have?
what about the cg issues? I heard that they suck since they are heavy and mess up balance. Also-can you still do tricks with them on?
