RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   elevated tail rotor (https://www.rcuniverse.com/forum/electric-rc-helis-167/1822949-elevated-tail-rotor.html)
kevino 05-17-2004 05:50 PM
elevated tail rotor
1 Attachment(s)
Hello! I've been reading this board for a while and thought I should share my elevated tail rotor mod. It's just some rubber tubing heated into the curve I wanted and the boom pieces are just friction fit into it. Just sharing a fun idea.
F.A. 05-18-2004 12:17 AM
RE: elevated tail rotor
so iwas just going to post about benefit from this..
is there one with the tail being elevated and DD?
how high should you go?did you try diffrent levels?
i'm down and may do this mod if you have reached success with it.
thanx, chip
Super-Hornet 05-18-2004 10:18 AM
1 Attachment(s)
Hi all
This is my Version 3 Elevated Tail Rotor. Anyone can guess what material is it for my Vertical and Horizontal Fin/Stabilizer? Hehe.
Super-Hornet
asainz320 05-18-2004 10:37 AM
What do you gain by doing this????
crazhorse 05-18-2004 11:38 AM
from what I've read it gets the TR out of the downwash of the mains, and keeps the TR from hitting the ground........
kevino 05-18-2004 12:06 PM
The benifits are just what crazhorse mentioned but, the other feature I've found is since it's rubber tubing it's slightly flexable at the angle. A crash that is boom first, gets deflected. Plus...it looks cool....:D
JZGOON 05-18-2004 12:15 PM
how do you guys make your own brushless motors, and what do you do for an esc, make your own? buy?
asainz320 05-18-2004 05:28 PM
It does look cool [8D].
Super-Hornet 05-18-2004 07:05 PM
Hi JZGOON
The brushless tail motor is from CDROM motor. I rewind it with 10 Turns per pole. I use Castle Creations PHX-10. U can build your own Brushless controller but I would say the task is time consuming and not worth the time and money. I recommend just buy it.
Oh... One thing for sure is that elevated tail rotor will prevent (Or just reduce) the tail rotor from hitting the ground if u land tail section first. In real helicopter, UH-01 (Huey), UH-60 (Blackhawk), Apache, SeaHawk, and many more are Elevated Tail Rotor.
Super-Hornet
JZGOON 05-19-2004 05:59 AM
cool!!
what about for the main motor, does it have enough power for that? or do you need a bigger/stronger motor?
Mhale71 05-19-2004 06:04 AM
i know, if you want to put a huey, / cobra / apache shell on it, they all use elavatet TR's
