Piccolo Fun tail problem.
Hello all,
I recently got a P-Fun and it's a real bute'. However, at times the tail does this thing where it just swings its' tail round. I can't seem to find a reason for it happening. It doesn't seem to matter whether the battery is new/fresh or old/used. I'll have it perfectly set up, have a good flight, (30sec./1min.,) with no events, land, rest and lift-off again and sometimes the tail just goes off on its' own, usually after a few seconds of flight. It seems to happen once a battery at or near the beginning? I'm still monitoring it to see if there is a pattern. This just seems to be too random, you don't know when it will happen and it always seems to happen for no good reason whatsoever. ????????????????Any thoughts? |
RE: Piccolo Fun tail problem.
have the same problem with my feda dragonfly.
i'm using seprate electronics (a difrent speed controler for the main motor and another for the tail). a GWS PG03 Piezo Gyro and a gws reciver. a 8.4 v batt i tried evrything - i replaced the tail motor,the gyro and the reciver -so as the motor controlers and the problem remain. |
bad gyro element or maybe glitching rx?
| All times are GMT -8. The time now is 04:32 PM. |
