elec. rec. whatever not working
Is there anybody out there that has a Minidragon fly that has had a problem with the speed controller? I can NOT get this ---- back up into to the air!!! I have changed the speed controller (for 50 bucks) and no luck.
I have changed the leads into the receiver and the and trx. is working fine.I also checked the motors and they work find.Battery power is up and I don't know what else I can test????? Please HELP me with any information that can get me flying. By the way I just got a RAPTOR 50 VS 2 Talk to you later Tommy AZ |
RE: elec. rec. whatever not working
Charge up the batteries fully and check the voltage on any type of volt meter. If it's below the volts printed on the battery, you might have a dead cell or two, and most likely have to replace it.
Thanks for the reply, but I tried that and the battery was good. I have E- mailed GWS about the problem but have gotten no answers. The transmitter works all of the channels and the board shows a green light. I think the problem is either in the transmitter doesn't "0" the speed controller to tell it it can "start". The safe start override "THING" that is built into the speed controller could be the problem.I have know idea what to do next? Just bought a RAPTOR 50 with the bells and whisles, But I still like to get this little thing flying again. |
