RCU Forums
-   Electric RC Helis (https://www.rcuniverse.com/forum/electric-rc-helis-167/)
-   -   Sim for windows XP (https://www.rcuniverse.com/forum/electric-rc-helis-167/5064544-sim-windows-xp.html)
gypsy7474 12-01-2006 11:19 PM
Sim for windows XP
I have windows xp, FMS wont work with my transmitter due to no drivers. Are there any other free sims out there that will work with XP ? I just bougth a Falcon 40 & dont want to tear it up quite yet, im totally new to helo rc & wish to learn first.
Thanks.
turbotb0205 12-01-2006 11:29 PM
RE: Sim for windows XP
what do you mean no drivers? install your transmitter as a "generic" through the game controller config in your control panel
does windows even recognize the tx is plugged in?
if it does and fms just doesnt wanna recognize it there is a simple solution
search for a program online called JoyToKey its a universal joystick adaptation program
that will allow you to prgram what does what EG all the sticks correctly it will also allow you to use
the analogs correctly "proportional = analog to a pc"
klamathpro 12-02-2006 12:27 AM
Your Falcon 40 TX is perfect for FMS, I have the same one. You need to download PPJOY to get it to work with the serial port. Do a search for PPJOY.
TitaniumZX 12-02-2006 08:35 AM
Here's the [link=http://drn.digitalriver.com/product.php%5Bid%5D75176%5BSiteID%5Dsoftwaregeek]link[/link] to download PPJoy v0.83.
jbalat 12-03-2006 10:44 PM
PPJoy is what I use also..
I just bought a copy of Clearview, only $30 US and the guys have already done about 5 updates, so its getting better all the time.
It actually uses real photos for the scenery. Much better than FMS in my opinion..
Download the demo and try it out once you get your joystick working
http://rcflightsim.com/
CJGFX 12-29-2006 01:08 PM
Well I've been trying for over 3 hours to get FMS to work with my Walkera #4 TX and I still can't get windows XP to recognise the Controller. The Walkera TX came with a serial plug so I inversted in a USB dongle. I can get PPjoy to see the port is open but I can't get a signal from the TX. I don't know if it's the coputer or me, if anyone has an ideas??
Would be most appreciated.
JRexA 12-29-2006 09:08 PM
Check out http://www.smartpropoplus.com that might be a help.
smartpropoplus works directly with FMS or indirectly via PPJOY with anything
chchgsr 12-30-2006 01:36 AM
I too had excatly the same issue - I later found out it was the cable, had you tried another cable or checked the wiring?
CJGFX 12-30-2006 03:19 AM
OK Guy cheers,
I'm off for teh New Year Celebrations so I'll try it when I'm back and let you know how I get on......
CJGFX 01-23-2007 10:35 AM
Hmmmmm Well, I've done as everyone has said and rewired the exciting plug, changed the plug to work with the SMARTPROPLUS system and still no luck!!! I did manage to get e signal with the SMARTPROPLUS system but when it came to calibrating the controller in FMS the signal was jumping around all over the place. So after yet another 4 hours I've still not got my Walkera #4 controller to work with FMS. Has anybody got any ideas before I wipe out even more of my Helicopter? It's getting desperate and expensive now.
cheers,
Chris......
Kevinator9 01-23-2007 02:31 PM
1 Attachment(s)
Download ppjoy. When it is downloaded go to the "ppjoy" folder. In there is "setup.exe". Open that and it will install the folder "parallel port joystick". Then go to control panel and open "parallel port joysticks" which is a "configuration utility for joysticks that plug into the machines parallel port". Open that. Click "add". It will open the "configure new controller" window. Then change the "parallel port" drop down from "LPT1" to "virtual joysticks". Plug in and turn on your transmitter then click "add". Then ppjoy will go through downloading whatever it needs to and it may take a while. After that to use your transmitter on fms you need to do this. Open "ppjoycom" in the "ppjoy" folder and change the "serial protocol" to "zhen hua 5 byte protocol" then turn on (and plug in) your transmitter. You will see the "waiting for stream int..." change to "reading serial stream...". Then open fms (leave ppjoycom open reading the serial stream) and go to the "controls" toolbar then in that go to "analog controls". Then change from "no interface" to "joystaick interface". Then click mapping calibration. Change the numbers to the same as the picture down the bottom and then click "calibrate" and follow the instructions given. This process work perfect for me and there used to be a website with all this info on it but now it doesn't exsist I've had to sit here for 45mins typing it out. I really hope these 45mins make you able to use fms...
Kevinator9 01-23-2007 02:32 PM
Although that was for a df4 tx...
Dan D 01-23-2007 03:38 PM
I've used both the Dave Brown sim and the G3 both work great for me on XP, I guess you only get what you pay for. Dan
Kevinator9 01-23-2007 04:23 PM
But then again the falcon 40 is the same as the df4...
rcmaster123 01-23-2007 06:22 PM
[link=http://www.rcdiscuss.com/index.php?topic=76.0]this[/link] explains it very good.
CJGFX 01-24-2007 09:06 AM
Hi there Kevinator9
Thank you kindly for going through all that info for me I'm sure it will be of use to alot of other people too. I've been through everything step by step as you said, but I've a problem after changing the 'serial Protocol' as is won't change from "Waiting for stream init" to "Reading Serial" so I'm guessing that there's a problem with the Serial cable supplied be Walkera or the 'Serial to USB" adaptor isn't compatable. So I'll look into finding one of the newer cables I've read about on the internet. Or maybe try my Hitec TX.
Thank you once again for your help
Kevinator9 01-24-2007 01:27 PM
You need to turn on your tx and you need the serial port plug that looks like this:http://mobile-accessories.com/images/camflashtodata.jpg
ronf79 04-16-2007 06:31 PM
I have a falcon 40 and got fms to work using ppjoy. I had troubles at first because I was trying to use a serial/usb adaptor. I then tried the cable plugged directly into my serial port with frustration again. Finally I realized that my serial port was disabled in the bios of my computer. Once I enabled it and went through the whole rigamarole the same as Kevinator9 graciously typed, it finally worked.
