Would reducting ducted fan jet velocity increase efficiency?
CA
After doing some aerodynamics research and reflecting upon previous responses to similar questions, I have come to the conclusion that if you can reduce the absolute velocity of the thrust jet from a ducted fan, it may increase low speed efficiency. This may be used to increase flight times for a edf jet flown at park flyer speeds. Can anyone input on why this may or may not be a valid idea?
CA
RE: Would reducting ducted fan jet velocity increase efficiency?
ORIGINAL: RAPPTOR
static or dynamic??
static or dynamic??
FL
To increase the efficiency more and easier; i.e., smoother; inlet airflow is required. And, to increase eflux for higher speed and efficiency, reduce the exhaust opening to no less than 85-90% FSA with a smooth exhaust 'tube'.
CA
ORIGINAL: BeanerECMO
My Feedback: (41)
[X(] yep ,backwards. i have had very good results by speeding up the air, to the fan. the fan can only accerate incoming air. so, if the air starts out faster to the fan ,it will speed up the faster air...inlet and outlet are everything. if inlet area is smaller than swept fan area,then you need to have a, pluum affect in front of the fan. if not make the inlet a little smaller at thr fan.. also about 3 to4 inches in front of fan should be fan shroud diam. and straight.oulet size is according to thrust, needed and effulx. effifency times power,divided by diamiter..tail pipe out let size.
CA
ORIGINAL: RAPPTOR
My Feedback: (41)
im not sure about effency,but helps performance. higher inlet air speed,,,,lets say ,,,helps turn the rotor..like a, prop plane in a dive. so it is possible you could have less engine load,less amp draw,ect.. rotor blade pitch /angle is also in the mix ,for dynamic end results. that,{blade angle} will have a ,good deal to do with effeceny..rpm,fuel useage,amp draw,watts,ect,...
CA
How does increasing the inlet velocity affect your flight times for a specific battery?
CA
ORIGINAL: RAPPTOR
less rotor drag,, run it up to speed. then use an air hose ,blow in the ducts.. fan will turn faster......[X(]
CA
ORIGINAL: RAPPTOR
air hose or fan.. [X(]
