EVADER ELECTRIC FLIGT LAUNCH PROBLEMS
My Feedback: (9)
Yesterday went to the field with two friends to MAIDEN their NEW evader jets.
The result was two chrashed planes after the first atemp in launching them with the suplied bungee.
ANY SUGESTIONS TO AVOID THIS ESPERIENCE TO FUTURE USERS?
In both planes the bungee seemed to never release causing the planes to pitch into the ground.
Both launches deviated to the left gaining altitud, and then rolling and pitching into the groung.
Both crash sites never past the anchor point, and were almost parallel to the left to the anchor point.
Should the hook realease if you deviate to the left or right?
The hook realeses only if you manage to go beyond the anchor point?
You need to pitch down the plane on porpuse to release the plane as per instructions?
CA
I've had many successful launches with mine, and so has my friend.
Did you have the right amount of tension on the line? We go with the manuals number of paces, plus a few for good measure
The hook comes off everytime, right around the time it passes the stake in the ground.
Did you put the hook in the stock location??
Don
Don
