Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Need a Doppler Reading >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 10-24-2010 | 09:40 PM
Default Need a Doppler Reading
[youtube]http://www.youtube.com/watch?v=z-FWr8ll9lk&feature=youtube_gdata[/youtube]
Old 10-25-2010 | 07:46 AM
Default RE: Need a Doppler Reading
what brand f16 is that?
Old 10-25-2010 | 06:55 PM
Nitro Planes AirField 70MM f-16 kit we put in our own electronics<a target="_blank" href="http://www.nitroplanes.com/93a16-airfield-f16-skygrey.html">
www.nitroplanes.com/93a16-airfield-f16-skygrey.html</a>
Old 10-25-2010 | 10:48 PM
dditch's Avatar
I've used a program that takes sound and measures the speed using doplar. It's not a hard process once you learn it.
I could take a sample of this video and measure it, but I'll tell you, it won't be true speed.
Best way is to take your camera out onto the runway and set it at the end, then take a high speed dive into a low pass as close as you can to the camera, say 10-20 feet up and full throttle. Post that vid, then I'll take a short sound sample and measure it for ya.
By setting the camera down, you also get rid of the sound that's made with your camera person handling the camera.
BTW Nitroplanes has a new coupon code. Note that it's mispelled once on their main page.
It's EVERYPLANE, not EVERYPLANES
Here are current coupons:
[link=http://www.mycoolheli.com/coupons/nitroplanescoupons.html]coupons[/link]
Old 10-26-2010 | 03:30 AM
i have the same f16, can you post the links to your fan and motor?
Old 10-26-2010 | 04:55 AM
Thanks ... I willmake that videothis Sunday afternoon when we are at the flying field...
Old 10-26-2010 | 04:57 AM
Shane when you read this can you post the links to the setup? Im late for work already!  Jimmy
Old 10-26-2010 | 12:57 PM
ARC motor:
http://www.shop.chuckshobbies.com/pr...?productId=265
Wemotec Mini Fan:
http://www.shop.chuckshobbies.com/pr...?productId=150
100a esc:
http://www.hobbyking.com/hobbycity/s...idProduct=7341 I forgot when I made the video thatIused this instead of the turnigy esc
5s 2650mah 40c:
http://www.hobbypartz.com/83p-2650mah-5s1p-185-40c.html
28mm heat sink
http://www.lightflightrc.com/HTML/pr...Clamshells.htm
