Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Help from the pros
Old 05-25-2011 | 08:30 AM
Default Help from the pros
I'm having a hard time with my E-flite F-86. It's not giving me all
the thrust now. How do I verify if it's the motor or the ecu???
E.N.T.
Old 06-03-2011 | 11:37 AM
Default RE: Help from the pros
Trying to get some help from anyone . If it's the speed control
which is a Castle Ice 75 or the motor of the V15 fan? It doesn't
reach all the rpm's as before.
Thanks;
E.N.T.
Old 06-03-2011 | 02:39 PM
2 question. Is your flight battery charged to 16.8 volts assuming you are using a 4S. Did you change any programming in transmitter that may be limiting throttle? Also, make sure motor turns free and is not bound up. If motor doesnt turn free I would say motor is bad.
Hope this helps.
Keith
Old 06-05-2011 | 05:21 AM
Keith: I charged one of my batts. completely, dismantled the fan and motor,
everything is running ok. Did not change parameters previously, BUT still
running subtotally.
Hector
