Concept x 4s
Hello,
I have one of the original NitroPlanes Concept X. I have been running it with a 3s and it was all good but a bit slow. I put a 4s into it and the speed control wont arm. I tried an E-flite 30amp esc and it only will run at about half throttle... maybe it jumps to full throttle for a second but the throttle response is all jerky. I also noticed that the ESC got hot very quickly. I find it hard to believe that the stock motor and 64mm fan are overloading it. Is that the problem? Do I need a 50 amp Speed control?
