EDF inlet ring - value?
Looking at a new build and found my CG was a bit tail heavy. I have a E-flite 69MM EDF with the molded inlet ring installed. To get the CG more forward I need to move the EDF as far forward as possible. The inlet ring takes up about 1/2" in front of the fan. The unit is mounted in back of the wing about 2 inches back of the trailing edge (profile fuse). It would help if I can bring the unit up as close to the trailing edge as possible.
The question is can I eliminate the inlet ring and still have decent performance from the EDF?
Best, DennisT
Best, DennisT
Best, DennisT[/QUOTE]
The short answer is no. Many tests have shown aprox. 33% reduction in thrust without the ring ... Sorry, but you need it.
Greg
Greg
Probably good - but there are folks who are very familiar with the combination you are using - and they would be a MUCH better source of information than I am. Two options would be bench testing it with a Watt-meter and thrust guage or just flight testing it and playing with your exhaust area.
Hopefully someone will chime in with hard info.
Greg
Greg
