Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
A10 help
Old 04-02-2004 | 02:51 PM
Default A10 help
Hi,
a few questions for the GWS A10 with EDF55 150:
are the power/motor cables supplied with the kit capable to handle the requested current? (10-15 Amps)
Suggested batteries? (no KAN cells or LIPOLY, not existing in Greece)
What about retracts?
any mod?
thanks
Old 04-02-2004 | 06:23 PM
Default RE: A10 help
The power cables are plenty capable of handling the current required.
Batteries, a 7 cell 8.4 Volt NiMh pack, about 700-800 m/ah. They're good enough for about 8 minute flights a pack.
DON'T go above 8.4 Volts, the electric motors can't handle anything more. They will burn out really quick (like in a couple of flights) if you go to 8 cell 9.6 Volt packs.
The GWS supplied motors aren't long life anyway. THe EDF 50 3 blade units seem to last about 30 flights. Can't say what the new EDF 55 6 blade units will do, but probably about the same.
Retracts? No way. They will add weight. Just delete the undercarriage and the nose wheel steering servo, hand launch it and land it on is belly.
The secret behind this model is keeping the weight DOWN. It's borderline in the power department anyway, though if kept on the light side, it will fly o.k. (but not quick.)
Once the original motors have died, then look into some small brushless motors as replacements.
There have been plenty of threads on this conversion on this forum and I am sure that those who have already done this type of conversion will gladly share their experiences with you.
Good luck
Old 04-02-2004 | 06:24 PM
kramer's Avatar
My Feedback: (61)
The cables will be fine but loose the landing gear.Retracts will add too much weight.If you want retracts go brushless
Old 04-03-2004 | 02:38 PM
8 HE 1100 cells should work well. You will not burn up these motors as they are bigger and better than the ips motors. Someone over on ezone put retracts in his - but he also used lipos for weight reduction and he put a brushless upgrade in it for power. It flew well apparently.
