Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Alfa Model Mig 15
Old 05-19-2009, 01:28 AM
  #351
jumper666
Default RE: Alfa Model Mig 15
Maiden could not have gone better. The Mig was surprisingly smooth and docile. It had no bad tendency at all. It flew as if it were much larger and heavier than it is. It looks GOOD flying by.
http://www.youtube.com/watch?v=4fNNcx60DF0
Old 05-21-2009, 08:17 PM
  #352
skrez
My Feedback: (15)
Hi Guys,
Is Hobby Lobby the only place to buy the alfa Mig, is there any cheaper on-line hobby shops that carry them?
Regards,
Frank
Old 05-21-2009, 08:34 PM
  #353
jumper666
Mine had a little problem today. Midair.
ID:	1203337   Click image for larger version
ID:	1203338   Click image for larger version
Old 05-21-2009, 09:50 PM
  #354
evan-RCU
evan-RCU's Avatar
Hobby King sells them....
The Alfa's are not very rugged and also not cheap, that is the bad. The good is they are addictive and fly really well. Sorry to see one in pieces.
Old 09-25-2009, 11:50 PM
  #355
tommythecat
tommythecat's Avatar
Has anyone tried flaperons on the mig 15. I built mine with dual aileron servos, and am thinking about mixing flaperons, but I have no idea what to do or expect. If anyone has tried them I'd love to hear how much deflection you use, how well they work and whether or not you also mixed in any elevator. It would be great to be able to shorten this things glide. It's like the energizer bunny.
Old 09-26-2009, 06:40 AM
  #356
tIANci
tIANci's Avatar
Tommy ... personally I think its not worth it. If you want to slow her down come in shallow then hold her nose up to bleed speed or flare her good to shorten the glide (on approach ELEVATOR controls SPEED and THROTTLE controls RATE OF DESCEND). Try not to dive so hard on your turn from base leg to final and also come in low as stated earlier on. Hope this helps.
Old 09-27-2009, 05:25 PM
  #357
riots
I programmed the elevator to maximum deflection upwards ( dual rate ) on a switch and use that setting for landings with about 5 milimeters of additional travel I can now flare the thing pretty well.
i donĀ“t like to have my servos on 140% at all times , thats why i donĀ“t leave it like that and tune it down with expo ....small throws work pretty well at 90mph
as stated above elevator controls speed and the mig seems pretty immune to tipstalling,
iĀ“d keep an eye on low speed manuverability since the ailerons arenĀ“t terribly effective at low speeds,
that could be a problem when they only deflect in one direction .
might get hard to react when the wind blows the bird over few inches from the ground.....
have fun with your bird, it certainly is a great little flyer!
cheers
rio
Old 09-27-2009, 09:09 PM
  #358
tIANci
tIANci's Avatar
I think the Alfa MIG 15 is still one of the best for this size, got the looks and flies so nicely. Unfortunately, for me I will not get another, flying off gravel fields will just kill this lovely plane. I think getting it in a RED/SILVER scheme is best ... either the red top or tail.
Old 04-13-2010, 12:30 PM
  #359
bgm1968
My Feedback: (8)
I just repowered my Mig and have yet to fly. I put a edf fan, Mega Motor, 5 blade Alfa fan, 30c 3s 1320 battery and Phoneix 45 amp esc. It is pulling 41 amps and 414 watts. With a 1750 45c battery it is right at 540 watts. Has any one have flight experience with this setup?
Old 01-29-2012, 04:23 PM
  #360
jumper666
Put my Mig videos together in one place.
http://www.youtube.com/watch?v=x81lGvornh8
gb
Old 01-30-2012, 07:18 AM
  #361
Saburo Sakai
Saburo Sakai's Avatar
Thanks for posting that. Jumper, I've always liked that Alfa MiG since I first saw her over at Hobby Lobby.I saw the pictures after your mid-air "incident." What'd the OTHER plane look like?That Alfa's a solid little jet! I'm not flying my jets until I have another season of training with props at slower speeds, but I do have an H. Lobby MiG and when I can, I sure like the looks of that little Alfa.When things improve around the world (soon) I look forward to many, many more posts on this Alfa, and other fine planes
Godspeed!
Old 01-30-2012, 09:04 AM
  #362
jumper666
Yes, do get some experience under your belt before trying the Mig. As a 1st EDF, you might consider a Phase 3 F-16. It is an easy build, easy to fly EDF.
The attached videos are of Hobby Lobby's Mig and Saber
http://www.youtube.com/watch?v=aQGaRXoSDD4
http://www.youtube.com/watch?v=OvBGMUS_rzo
http://www.youtube.com/watch?v=mqhaneP5Xto
gb
