EDF for 87 inch vampire?
My Feedback: (49)
AZ
i know nothing about df but sounds interesting.i aquired a 87 inch vampire.wings are close to that of an extra.twin boom tail.do they make edf for this size of plane and where might i go to find info.plane weighs around 8lbs dry right now.would assume i need about 15-20lbs thrust?how do you measure thrust for what plane.for instance a 60 size plane takes from a 60-90.how do you figure what engine for your plane for edf or nitro df.thanks for any help.
CA
I would try looking at BVM's website (Bob Violett Models). They have large electric df setups. Not cheap, but I'm sure they are excellent quality.
Hope that helps.
Hope that helps.
NY
Add about 4 lbs for a fan, motor and battery, for an AUW of 12 lbs.
A good rule of thumb is 100 watts/lb for good performance so your looking at 1200 watts.
This will be a 90mm fan. Using a 5S lipo, the current draw will be about 65 amps, a bit much for my taste.
Going to 6S, the current drops to 54 amps (1200/(6*3.7)). With a 6Sx5000 mah pack, nominal flight time is 5.5 minutes (5*60/54).
For vertical performance you would need a 1:1 thrust ratio (12 lbs), which might be hard to do with a 90mm fan, but not impossible. If you don't need vertical then a thrust/weight of 0.6 (~7 lbs) would be fine for decent performance.
I suggest you look at Electric Jet Factory (www.ejf.com) and have a conversation with Robert Wagoner. cmreefer's suggestion is right on the money as well.
