What size Motor for ...........
OH
RE: What size Motor for ...........
Who is WTech ? Do you mean Wemotec? Also, are you sure it is a MIDI fan and not a Minifan? What is the diameter of the shroud in mm? The Rotor (fan) Diameter? Answer these questions and we can help.
Carl
Carl
My Feedback: (40)
NJ
Sorry I could not find the papers. But today my lady found it.
WeMoTec Midi fan Nr. MD 001-5 With 5,00 mm prop drive
Can accepts 600 size motors and 540 buggy Mtrs
Fan ID 90mm
Thanks for the feed back.......
Fan ID 90mm
OH
Angel,
Thanks much for the info. The Fan is made for large, high performance aircraft and while it may be something you want to keep for the future, it will not work in the HET-RC F-20 Tigershark. The F-20 is made for the Minifan 480, which has a 69mm rotor...much smaller than the one you indicated. As I am finishing the build of my second HET-RC F-20, I can tell you that the larger fan will not fit and even if you used a big hammer to make it fit , it would not work because the intakes are too small.
Carl
Carl
My Feedback: (40)
NJ
AAAAAAALLLLLLLLL Well
I will get the 2W , fan and the Phoenix 60. I thinks it comes with a BEC.
But I am more of a speedster. And I scratch build my D/F jets, propjet. I also have 2 big F-20 . But I got to get this little one.
I have a Shock Flyer but that not for me AT ALL.....
So the fan I have, will be good for what size motor ?
hi, i have 2 het rc d/f jets with the wermotech mini fan and a scorpio eurofighter typhoon with 2 knotronics fun 480-33 motors to put in. i was wondering if anywone is using these motors and what the amps draw was. thanks
