Aero Fever SU-27
Aero Fever SU-27
Check out BORIS! This is the new SU-27 from Aero Fever. 20 oz and totally nuts! This model can be made as a DF or pusher. Either way, a sweet plane. Comes with only the essentials and that goes for the instructions too. It was an easy build if you have done a foam pusher before. I set mine up with elevons and I am running a DIY motor from Daves. You can get these at http://www.aero-fever.com/index.php Now, where is that pesky little flying rat, Rocky?
Cheers,
Cptn.K
Cheers,
Cptn.K
RE: Aero Fever SU-27
Ok, just a quick update....incorporated the ailerons and added some decaling. Changed the prop to a 7x6, now the speed is unmanageable and I love it. Did I mention these are under $40 Can??? No, Terry, I am not affiliated to the product or the company. I just like to let people know there are alternatives out there.
Cheers and good flying!
Cptn.K
Cptn.K
