where is the center of gravity please:)
http://www.rcuniverse.com/forum/m_4267515/tm.htm[/link]
sorry for the double post dunno where to ask for that hehe.
NY
RE: where is the center of gravity please:)
If it were mine I would make a glider from heavy card stock, a simple profile fuse would be OK. I would make sure to keep the same wing area and shape. Then I would hand launch it, paying attention to its attitude as it fell. I would add a small amount of weight, in the form of a paper clip, to either the front or aft end. Continue doing this until the plane falls with a slight nose down attitude.
Once the fall has the correct attitude I would hang the glider by a piece of string. Continue moving the hang point until the glider hangs with the same nose down attitude. That's the CoG.
Transfer that location to your model.
