EDF55 Fan Removal
MN
EDF55 Fan Removal
I would like to install brushless motors into my EDF55's. How do you get the fans off to do this??? i have already remevd the two screws, tried a small sheetmetal screw. All that did was make the hole bigger. Fan hasn't moved.
thanks
thanks
FL
RE: EDF55 Fan Removal
Do a search, it is a common problem and I do not remember the solution. I believe it may be necessary to dissamble the motor to pull the shaft out. Good luck
Hurricane Larry
Hurricane Larry
