Own Design Jet DFJ
Own Design Jet DFJ
I have designed a simple 6mm depron foam ducted fan jet around the GWS EDF 64 fan unit. I am amazed by how well this model flies it being small, fast and stable. It is comfortable for park flying on half throttle with a brushless motor and really screams at full power. It can be setup with a blindingly fast roll rate although this makes the model tricky to fly. The model was designed, drawn in CAD, built and maidened within 3 days and has only very simple inlet ducting and paper tube outlet which seem to work well.
I am really pleased with how this model has turned out and so I am in the process of producing a set of plans that will allow others to try it (free of course)!
My setup is:
EDF64 with Eflite Park 400 (2025-4200)
18amp brushless esc
3s1p 1800mAh lipo (20C)
2 HS55's
4 channel RX
Rich
My setup is:
18amp brushless esc
2 HS55's
4 channel RX
Rich
RE: Own Design Jet DFJ
That's very funky mate.
Nice to see you don't need heaps of complex curved surfaces to get something good in the air, I might try you're plans.
