Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
4s cell help
Old 12-03-2006 | 09:11 PM
Default 4s cell help
newbe here so be easy...im building a twin edf f18..i have been building for years,but not alot of flying...so heres my question..if i run a single tanic 3250 4s pack..do i need to run a bec..i have been told no,but i want to get some more imput..anyways...the amp draw is 27 amps per fan, and the pack is 20c continus,so the pack has enough juice..thanks alot..stumpy
Old 12-03-2006 | 10:03 PM
CTulanko's Avatar
Default RE: 4s cell help
Stump,
The reason for running BEC has nothing to do with battery capacity or size or characteristics. BEC is run because most ESC's that run 4S or higher battery configurations cannot supply power to the motor and the receiver without generating excessive heat or shutting down. The amount of heat and shutdown is realative to the number and type of servos used, along with the model of ESC. So in answer to your question, should you run BEC on a 4S or larger power setup? The answer is yes.
Carl
Old 12-03-2006 | 10:09 PM
being on 3 servos...i hate asking the same question..i just want to be sure..thanks for your help..Stumpy
Old 12-04-2006 | 06:11 AM
CTulanko's Avatar
OK, let me clarify it a bit more...if you are using a 4S or larger power setup, do not use the BEC from the ESC. Get a U-BEC or small battery pack and power your receiver from the U-BEC or battery.
Carl
