New Product - RA260 Micro Air Retracts.
The AirPower - RA-260 Micro Retract Set was specifically designed for use with 70mm EDF planes. Ideal for model planes up to 3.5 lbs. this very complete retract set is ideal for kits, ARF's and ARC's in this size and weight range. If you've always wanted functioning air retracts in your 70mm EDF planes, this is the retract set you've been looking for.
RA-260 Air Micro Retract Set - 3 Gear
http://www.airpowernet.com/twe/prod...products_id=642
RA-260 Air Micro Retract Set - 2 Gear
http://www.airpowernet.com/twe/produ...roducts_id=655
Video :
http://www.airpowernet.com/upload_im...t/SANY0009.wmv
User Guide:
http://www.airpowernet.com/upload_im.../260manual.pdf
● Low Profile (. 472" - 12mm when retracted)
● Frames 6061-T6 & Trunions 7075 aviation grade aluminium
● Air up, spring down
● Every Retract Weight : 10 g / All Parts 88 g.
● Suitable for EDF & Warbirds Models up to 3.5lbs
Video :
User Guide:
RE: New Product - RA260 Micro Air Retracts.
We have installed the plastics one in the hatch door , and rush open by the shock power of the nose wheel.
My Feedback: (61)
NJ
Hi,
I just got my retracts set plus a whole bunch of other accessories etc. All I can sy is WOW. The retracts are awesome and TINY. I can't wait to start installing them in all my small projects.
Thank you and GREAT prducts..
Best Regards,
Adil
Best Regards,
Adil
