Synapse Ducted Fan issue
The ducted fan part of the motor has removed itself. I say itself because I did not take it off. Just kind of flew off during a throttle test.
The Instructions look as if this brass part is not "supposed" to come off. I see the 2 grub screws but have no idea how to tighten them to the motor shaft without drilling though the fan shroud. Anyone?
MO
RE: Synapse Ducted Fan issue
The same thing just happened to my friends this weekend (only 3 flights on it) He did proper break in per instruction book.
The only way I can see to get to those screw is to drill a hole thru the case then plug with hot glue or epoxy after you've reinstalled the motor. We were thinking of grinding a flat spot on the shaft to help prevent future happenings.
NJ
Drill a small hole big enough for the proper allen wrench, dab on a little locktite, and install. If you can file a flat spot on the motor shaft, I would definately do that.
You shouldnt need to plug the hole. If you do, do it from the outside of teh case with tape.
jak
jak
