Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Which design will be FASTER? >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 05-28-2008 | 07:34 PM
Default Which design will be FASTER?
I'm looking to make a pretty quick EDF jet.. assuming all other things are equal, which would be faster? A single engine, or dual engine configuration, assuming the thrust/weight ratio is constant?
Old 05-30-2008 | 08:07 PM
P. Richards's Avatar
Default RE: Which design will be FASTER?
With two fans you have the weight penalty if you are going for speed
planes such as the Electra single edf unit is a very slick low drag airframe.
when you add twin tail fins and wider airframes then you have the drag penalty.
The F-16 is a well designed full scale single engine fighter. Planes based on that same plan form do
very well as models. If your favorite plane happens to be a twin you can still build it
and install a single fan, you save weight and still have good performance.
The yellow Aircraft small F-18 flys great with a single 120mm fan. Some designs like the
Mig 29 will not allow a single and still look scale but it can be done.
P. Richards aka SwatTeam
Old 06-01-2008 | 10:53 AM
wouldnt the second fan's thrust more than make up for the weight penalty?
Old 06-01-2008 | 11:52 AM
tIANci's Avatar
The airframe is everything in the sense that it will be the main hurdle ... ever seen a small 27" hotliner like the VIP Racer go like stink on a mere brushed Speed 400? Planes with a 2nd EDF unit will have a bigger fuse cross section, meaning more drag for speed.
