Replacement fan for older Kyosho F-16
UT
I need a new fan for my Kyosho F-16. This is the discontinued version F-16. Same fan as they used in the T-33. It does not use the DF55. It has a 74mm diameter, 28mm hub, and 5 blades.
I have seen one post suggesting substituting the wemotec HW 609-L, but another post says it has a 38mm hub. A third post suggests using a Kamdax glow fan, Part No. 101-1 CTDF 80 Fan (Glow Fuel), but my web searches have found no dealer from which to purchase.
Anyone "been there done that"?
Thanks for any help you may offer.
