Tam Jets 1:8 F-16/JT100
Being in the right place at the right time is a wonderful thing. That happened to me when I was at E-Jets and was introduced to the incredible TJ-100. This fan is just the right balance of fan sweep area, motor load, cooling, and weight. I have been flying this fan in Tam Jets 1:8 F-16 and it is a pure joy to fly around the sky. I have had this F-16 a week now and have learned a lot about it and want to get it out to everyone. This weekend I am taking it to Spiderman Jet Event in Indiana and will have my eagle tree system running to get a lot more data together.
RE: Tam Jets 1:8 F-16/JT100
Data Sheet Tam Jets F-16 1:8
TJ-100 Fan (100mm) Neu 1518 1.5Y
TP5000 mah battery 12s
3700 watts 85 amps 44v
Intake 10 sq in, 9.4 sq in(fan sweep area), exhaust 9 sq in
224 watts/pound
Average flight time 4:00 3400mah used
1 min at 3700 watts (224 w/lb)
3 min at 2700 watts (163 w/lb)
Weight 16.5 lbs (264 oz)
Motor/Fan 14 oz/13oz (1.7 lbs together)
Airframe 11.5 lbs (185 oz)
Battery 3.25 lbs (52 oz)
72” long
51” wing span
5.3 sq ft wing area
50 oz / sq ft Wing loading
after spiderman at MAC I will post alot more data from my eagle tree system
224 watts/pound
72” long
51” wing span
5.3 sq ft wing area
