11.1V 4000mAh 15C "Exceed RC Fusion Power Series" High Performance Lithium Polymer Battery
I bought the Exceed RC F-35 Radio Remote Control 64mm EDF RC Jet.
- I wanted to know if this model of jet that can be used pots 11.1V 4000mAh 15C "Exceed RC Fusion Power Series" High Performance Lithium Polymer Battery?
- It will damage the engine?
- Tell me who put batterie that lasts for more?
Thank you
Thank you
TX
RE: 11.1V 4000mAh 15C "Exceed RC Fusion Power Series" High Performance Lithium Polymer Battery
thats sounds like a really big battery,, the stock one is only a 1300mah, a 4000 will be bigger and weigh a lot more . a 11.1v is a 3 cell they will be the same voltage, just a bigger size. 4x as big as stock
So you'll have Much Longer Flight times, but getting that to balance, you might have to add more weight, then the motor has to work harder, and struggle to keep it aloft. So might fly longer but be less fun to fly...
Recommend that battery that is a little more powerful than the stock?
Any suggestions
Any suggestions
