Phase 3 EF-16 ARF
Phase 3 EF-16 ARF
These are pics of my Phase 3 EF-16 . It's using stock ESC & Motor, 2 Hi-Tech HS-55 micro servos, and the Spektrum AR6100 receiver. I hand painted it with a water based, high gloss latex. I thought it came out pretty good. Very easy to build. Going to cover the bottom with a clear chassis protector, install Rare Earth Magnets to hold the canopy in place(it comes with a sliding lock witout a spring), and add chrome striping to the bottom so I have a better chance of not crashing...not saying I won't but it's a better chance not to anyway! Let me know what you think and any other pointers will help!
Aloha From Hawaii!
Aloha From Hawaii!
RE: Phase 3 EF-16 ARF
Yes that is a water based latex that I picked up from a local hardware store here. Took a couple coats, but worth the effort! Thanks for the compliment!
CA
Hi All,
You might check these Screw Mounts and Cheater Hole Support out if you like being able to service the motor compartment of your P3 F-16.
http://www.rcuniverse.com/magazine/N...roduct_id=3429
http://morganmill.com/RC/rc-site-10-7-08_024.htm
Cheers!
Gary
Cheers!
Gary
MA
no I haven't flown it yet, weather has been very uncooperative, I'm going to get a seasoned pilot to test flight it for me and trim it out, That way I don't have a repeat of the first F-16 I owned
DUmp the stock ESC and go to Don's RC and get a 40 or 60 amp pentium. I would not run that stock ESC on anything except a cheap foamy 3D plane. All my buddys have replaced them.. It gets hot even at 18 amps on a Stiffy...
CA
I finished mine last weekend and have put about 10 sucesfull flights on it so far... really a pretty cool jet...
I went for something similar to the Alaska Air Defense squadron:
I read alot of threads, but mostly I flew one at winnamac last year with the stock motor and stock controller. It was quite hot after a 3S flight, and really hot after a conservative 4S . I switched to a Dons wicked motor, so I had to switch 41 amps at 540 watts on a 4S.
I just dont trust the controller. I have it on a 3s Stiffy with a 400 on it and it gets too hot for my comfort at 18 amps.
I suppose you will be ok if you run everything stock on a 3S likely in all fairness.
AZ
okay i just ordered this bird last night. Im looking for a gear set to install fixed as i like the more "scale" look and the takeoff and landings. Any Idea ive found a few but im not sure if there the right size. Lemme know thanks!!
here's one i found???
[link=http://rc-castle.com/shop/product_info.php?cPath=116&products_id=463]Landing gear posibly for phase 3 f-16?[/link]
AZ
Just got mine in the mail today!! Man i cant wait to get this thing in the air!! Ill post pics as the build goes!! Someone please give me some ideas on putting a fixed gear on this bird!!
Sorry, no idea about gear. I totalled mine btw! turns out trees are no good for these things...but i had about 20 great flights before that happened. oh, and i already got my replacement kit for it! so back to old drawing board!
AZ
Just maidened my f-16 today and all i can say is WOWThis is now my favorite bird!! Im running sto esc, fan unit, motor, with HS-55 servos and a AR6100,eflight 20c 1800 mah lipo and dx6i Tx. Flew 3 or 4 2-3 min cruise flights with no heating in either the esc or lipo. Great plane plenty of go fast and easily built. I give it a ten!!
