Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
EDF help..
Old 01-21-2009 | 08:25 PM
andrewtexas123's Avatar
Default EDF help..
When I give my EDF throttle it makes a high pitch sound and doesnt create much thrust what do you thinks going wrong? I Have this plane (Useing the stock fan unit and mtor..):
http://www.theworldmodels.com/para/p...airplaneid=208
First EDF so I gotta ask for some help!
Andrew
Old 01-21-2009 | 10:30 PM
giddyuperic's Avatar
Default RE: EDF help..
Is the blade rubbing on the inside of the case??
Old 01-22-2009 | 09:37 AM
limeybob's Avatar
Fan secured to motor shaft?
bob
Old 01-22-2009 | 07:54 PM
cyclops2's Avatar
Do you know if the spinning rotor, is spinning in the correct direction ?
