Honey I blew up the 64mm Mirage!!!
![](/forum/images/badges/trading_plus_member.png)
AL
I ran two 1300 packs thru the motor before I assembled the plane inorder to "break" the rotor in. This afternoon I flew the plane for the first time. After I got the plane trimmed out I throttled up and it flew great for about 30 seconds and then things happened pretty fast. It was really flying nice and fast. Quite a bit faster than the F-15 64mm. I guess the rotors couldn't handle the stress when the rotor un-wound in the air. See attached pictures. When I got home I took off the rotor and ran the motor. I seems like a lot of vibration is coming from the metal rotor adapter which is attached to the motor shaft with two set screws. I'm not really sure if or how I can get the vibration out of the rotor adapter. I don't guess Starmax has improved their rotor adapter like they did for the 70mm motors???
Just for safety I always stand to the rear of the fan no matter the size... Just wondering if anyone had the rotors fly thru the side of the plane while they we're doing a static runup? Just a guess on my part but my thinking is that the parts would lose momentum pretty fast after they seperate and bounce thru the foam. Any experience or thoughts???
Fred
Fred
You bring up a serious point about EDF. High powers/RPM & no protection.
I tie my planes down with 1/4 Nylon line to test them. I KNOW if it blew out, I would let go anyway.
Not to smart in a basement or garage ??
![Big Grin](https://www.rcuniverse.com/forum/images/smilies/biggrin.gif)
I have only overrevved 1 Fan delibertly. GWS 40 mm. Went so high the noise became 1/2 as loud NEAR WOT. 2 Hyperions 5800 KV running on a charged up car battery. Hard to tell if I became afraid as it ran quiter at higher revs.
![EEK!](https://www.rcuniverse.com/forum/images/smilies/eek.gif)
MO
Ftherrmann: I am interested in this mirage, aside from the edf problem how do you like it? does it slow down well when coming in to land? or do you need lots of speed to land, and can you put a larger battery in it? like maybe a 2100 3 cell?
Thanks for the input
I have had nothing bad happen to my EDFs apart from once I was doing a bench test and a fly flew right into it. he flew out the other end at 1000000000000MPH. I thought he must be one stupid fly I mean its not like he didn't have a choice
