FULL Scale EDF- F- 100D Sabre
#51
Hello Guys, I am VERY MUCH planning on getting one of these beauties. Iilia, have you test flown the EDF version? I am planning on either a Midi Pro or Stumax (altough a bit on the expensive side but the sound of the stumax is second to none in the EDF world).
#52
Hello Monza,
I agree with you regarding the Stumax and I am shure this will be a nice setup. I have no concerns about the extra weight as it is known that the Hun flies better on high wing loads.
Sorry, but NO - we could not make any test flights as "Daisy", a cold front has brought lots of snow and it is extremely cold now in Germany.We have to move it to a later date. Meanwhile I have "ripped off" most of the components to make some changes. It is mainly a repositioning of the batteries and saving some weight using a smaller but stronger cylinder to operate the gear door.
I am also very busy on the EDF redesign of my Eurofighter.Due to many many requests, I decided to make an EDF conversion kit and at the moment I build a customer model and document the EDF building procedure- but thats another story.......
Ilja
Ilja
#53
![](/forum/images/badges/trading_plus_member.png)
Have one of these it still needs assembly it seems other projects got the bench.
Nice to see one being built and an EDF conversion on the same thread.
I did some sub assembly of the wheels and axles and the wheel drags on the axle a bit.
Look forward to seeing how its finished. If I was going to EDF mine it would use a
Castle CC110HV controller. The castle link with usb adjustability makes it hands down better.
On the fence about fans, motors and batteries.
#54
Finally it has happened !
I have test flown the Hun a few days ago . The plane has had several modifications and I used very heavy components, all this made the test model very heavy. The total weight is 5400 gramms.
The model has been flown with the main gear opening closed - test have prooved that this "cheater hole" is useless, so I made a vac formed to close the wheel doors. Thrust is slightly over 3000 gramms, the tail pipe is yet NOT tapered down.
The video can be seen here:
http://www.youtube.com/watch?v=eNZ95_hq7Es
sorry for the quality, but I did not plan on making a video. At least it gives an impression of the overall performance.
I will try now to reduce the weight and optimize some things for the nxt flight tests.
Ilja
Ilja
