Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Throttle cutting out
Old 02-24-2010 | 11:41 PM
gabe_tuft's Avatar
Default Throttle cutting out
Hey guys,
I just installed an E-Flite Delta V 65mm unit with the E-Flite 40A ESC. I'm using Zippy 4S 2200mah 30C batteries.
Every time I throttle up the power will cut out at about half throttle. I get lucky if I throttle up really really slow and can get her to work. Any ideas on what may cause this?
Thanks!
Gabe
Old 02-25-2010 | 12:13 AM
Default RE: Throttle cutting out
Gabe,
any chance you have a watt meter available? That would be able to give you enough information to help solve your problem (at least eliminate some possibilities).
Old 02-25-2010 | 12:18 AM
Just read the specs for that motor and recommended ESC is 60A with a 3S battery.
Old 02-25-2010 | 11:11 AM
gabe_tuft's Avatar
Answered my own question this morning. I needed to reprogram the ESC. Flies great now! This bad boy is actually faster than my Habu. Easy hand launch too.
Thanks for the help boys!
Gabe
