Pantha
Purchased Texas RC Planes Pantha. Pretty planes, solid construction. The only problem is the C.G. The manual says 125 mm from leading edge but it is not correct. If you take the wing only in your hand and measure 189 mm down the middle, that is the C.G.
Hope this help someone.
One other thing. i also had to use all of elevator throws for it to fly well. I also mounted my battery in the nose by cutting out underside of the nose.
The plane fly’s great comes in a bit hot but when she touch down it stick to the ground and taxi great.
