RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   Thunderbolt A-10 (https://www.rcuniverse.com/forum/electric-rc-jets-198/10779999-thunderbolt-10-a.html)
Jeanskydive 10-24-2011 07:08 AM
Thunderbolt A-10
1 Attachment(s)
Hi scale Fans....Start to assemble the A-10 from Nitro Planes this one with 1500mm wing span, with power set-up Mega 1625/2 with 5S-5000 LiPo HET 70mm fan., in progress Cheers
srt10 10-24-2011 01:46 PM
RE: Thunderbolt A-10
that looks cool man! ;)
Jeanskydive 10-24-2011 02:45 PM
1 Attachment(s)
Some progress , now waithing for the retracts gear nex, . Cheers
chcarlos 10-24-2011 03:02 PM
Which retracts are you going to use?
Jeanskydive 10-24-2011 07:42 PM
1 Attachment(s)
The RC Lander , batteries fit perfect plenty of space even for 6 LiPo , fly test with is set-up 5 LiPo.I change the servo cover for flat one , more scale . Cheers
djsqueeze 10-24-2011 08:23 PM
Even though I've got 3 on the floor and one in the box, I'm jealouse. That is my favorite airplane. Keep up the good work and pics!!. You're doing a beautiful job with it. (??? Are your landing gear going all the way in or will it be like the real A-10, where it can still land wheels partially in the wells??)
Jeanskydive 10-24-2011 09:37 PM
1 Attachment(s)
Partially in the wells, , nice on belley landing!....Cheers
rcmiket 10-25-2011 03:17 AM
1 Attachment(s)
Looking good A-10's "ugly but well hung" One of my favorites.
Mike
Jeanskydive 11-02-2011 06:25 AM
1 Attachment(s)
Retracts video : [link]http://youtu.be/_NiSiBHFwes[/link] ready for doors wheels in progress , landing gear installation complete. Cheers
Larry Dudeck 11-03-2011 02:58 PM
Did you purchase just the airframe?
Never mind, found what I needed to know.
Jeanskydive 11-03-2011 05:02 PM
1 Attachment(s)
Almost ready for maiden, Cheers
gary41 11-03-2011 06:37 PM
Good job! Good luck on your maiden!
-Gary
Larry Dudeck 11-04-2011 10:17 AM
1 Attachment(s)
What are the materials of construction?
I just lost my 52" WS A10 and have a pair of 70mm fans, motors, ESC's, etc., etc. just looking for a home.
I would consider this air frame only, as long as it is not foam.
Jeanskydive 11-05-2011 05:57 PM
Hi Larry Verry sad affair, this is one is just perfec all balsa- plywoo fuselage ,1056 mm fuselage length, 1500 mm wing span, check with Hobby King [link]http://youtu.be/B9DrKVrEJ0M[/link] http://ep.yimg.com/ca/I/yhst-1721025...2180_204867474
Larry Dudeck 11-06-2011 08:18 AM
Jeanskydive,
Thanks for the video link.
Up till now I have steered very clear of ARFs in general but this one seems to have a lot of potential.
What is the fuse/wing covered with?
2walla 11-06-2011 11:14 AM
Looks pretty decent. I have the jetarrows all composite a-10 that is the same size and 5times the price. If you keep it light it should fly great!
Jeanskydive 11-07-2011 08:32 AM
1 Attachment(s)
The covering look like plastic film with flat paint. Cheers
Jeanskydive 11-18-2011 08:07 PM
1 Attachment(s)
The weight of the A-10 come to 5.9 pounds no batt., full gross weight for take off come to 7.1 pounds,with 5S-5000 65 C LiPo., I read each motor close to 40 amps, ea., 1,400 watts on both , so far so good., maiden nex. Cheers [link]http://youtu.be/TqiQr9XJJG0[/link]
chcarlos 11-29-2011 02:19 PM
Have you flown it yet?
I just received mine today. It arrived with very minor damage to one wing tip [simple repair] and the plane looks great. Now to accumulate all of the electronics and gear.
Jeanskydive 12-02-2011 09:31 PM
1 Attachment(s)
I did some running test and look good , I put on skis and wait for first snow. Cheers [link]http://youtu.be/Z6Y-LfWvPIw[/link]
Jeanskydive 12-29-2011 10:49 AM
1 Attachment(s)
Maiden for the A-10, day almost perfect with no wind, weather temp. -2F., power set-up with Mega 1625/2 , batt. 5S-5000 LiPo, plenty of power with this dense cold air, probably need 6S-liPo in thin air in summer time, will see, fly verry nice easy handling, and have a good speed average . Video clip maiden lift off nex. Cheers [link]http://youtu.be/lmxLYtVb5yA[/link]
Jeanskydive 12-30-2011 10:10 AM
Landing a bit bounce but ok., http://youtu.be/R6FIYGwPIsU and motor test full blast : [link]http://youtu.be/VQDdMeqqrNk[/link]
gary41 12-30-2011 10:29 AM
Good show! Nice going! Looks cold, way "up there". That's why I moved from Michigan to Alabama!
Regards,
Gary
Jeanskydive 12-31-2011 10:23 AM
1 Attachment(s)
Yes Gary winter time here now, have to live with-it....Cheers
neilh2 05-06-2012 03:28 PM
The A 10 looks great. I am in the process of putting one together. I am concerned about the Motor/ fan assembly. It is the Detrum combo for $47 with ESC and servos. SO cheap that I have a confidence problem. Do you have any experience with this maufacturer? The motor is an out runner. I understand I must balance the rotating unit. I dont know how to do it. Should I just buy a new power train set to satisfy my concerns? I hate to throw out two $47 combos and start over? I havent installed yet .
