B-57B Build
1 Attachment(s)
Scratch built Canberra. Just about finished. Just need to do a cockpit.
RE: B-57B Build
Very nice Capt. Is that flitemetel on it?
RE: B-57B Build
Fantastic classic jet ;)
RE: B-57B Build
Covered with chrome Ultracote and weathered a little.
RE: B-57B Build
Absolutely fantastic. I was just thinking about the Canberra this week. Nice to see it here. Thanks.
RE: B-57B Build
Capt G,
That's awesome! What's the size and fans/motors? I just received the plans for Chris Golds' Canberra and am planning finishing it as an EB-57. Rob |
RE: B-57B Build
Thanks for the kind words. It has HET 700 -60 2610kv motors with the HET 700 fans. Scales out at 1/9th at 86" span. Weight is about 19.5 lbs with batts on 6s lipos. over 1400 sq in wing area. What are Chris Gold plans?
RE: B-57B Build
Capt. G,</p> </p> The Chris Golds design is almost the same size as yours. His is 84 inch span and 18 lbs. His is an older design - he flew the maiden on 3300 NiMh cells. I'm going with two 8s 4000 Lipo's and Wemotech Midi fans. The switch to Lipos will take almost 3 pounds out.</p> </p> </p> Rob</p> |
RE: B-57B Build
1 Attachment(s)
Cockpit is done. Kind of minimalist until I can find a couple scale 1/9th commercial ones somewhere.
RE: B-57B Build
I reckon that would suit 2 turbines aswell!
Beautiful work!!!! |
RE: B-57B Build
1 Attachment(s)
Maiden attempt today. Had to abort when motors were cutting out. Posted a vid on you tube but can't find it.
RE: B-57B Build
Here it is : http://www.youtube.com/watch?v=x2PC4Rn1JEU
RE: B-57B Build
very nice, I always liked the B-57Bs!. Best of luck finding out the problem with motor cutting out and then successful maiden flight.
| All times are GMT -8. The time now is 10:29 PM. |
