Duct fan THRUST????
OK I am not a E D F whizz and maybe I have missed what is the important info on duct fans, that being said, why isn't the thrust output given for these units?? I know the data will change with different batteries and such but I have been reluctant to purchase without the manufactures thrust info. whats up?
Because its different with different c rated batteries and different ESC's
What specifically are you trying to accomplish? |
I understand that! I wont purchase anything unless I have some sort of info as to the capabilities of what I am spending my money on. What is the minimum and max thrust out put? all units are not the same, no matter the size, It appears this info should follow some sort of standard. The manufactures seem to use a haphazard set of parameters to sell their units and I have to rely on others to find out what a particular unit can do. I don't want to experiment and spend my money to get info the manuf. should supply.
This the F-14 I saw in another thread?
Do yourself a favor, give Gary a call at E-Flux RC He knows more about EDF setups than most of the rest of us put together. |
You are familiar with my f-14 build we have spoken before, but I am not seeking assistance with fan units I was just wondering why more info isn't available to the buyer. no matter what they call it if you want to "go" ya gotta have the thrust to do it! would you buy a turbine with out thrust data? it's like reading a long advertisement about a product but no price is given. which I find suspect.
I will keep Gary in mind if I need EDF INFO. Thanks |
You could try fanCalc
www.ecalc.ch → fanCalc Vriendelijke groeten ;) Ron • Without a watt-meter you are in the dark ... until something starts to glow • • e-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC • |
It's more than just simple numbers. There's motor size, motor kv, brand of motor, lipo brand, mah. size, ducted versus open duct, the list goes on. No way to say for sure. Look at jet fan, Schubeler or Wemo. They gives all kinds of info on different parameters. Sounds like your not looking in the right area or your looking at cheap Chinese fans.
Originally Posted by donnyman
(Post 12628763)
https://cimg5.ibsrv.net/gimg/www.rcu...5bfe149b54.jpg There is only one thrust that counts, fitted inside the model. https://cimg7.ibsrv.net/gimg/www.rcu...e68d21c606.jpg Hook it up to test it. https://cimg0.ibsrv.net/gimg/www.rcu...f24a8c2918.jpg Gives me good idea how will it fly well in advance. https://cimg1.ibsrv.net/gimg/www.rcu...e68988643c.jpg Regular homework. https://cimg7.ibsrv.net/gimg/www.rcu...58a6446018.jpg It's all in the log books. |
OK! I am aware of all that was said here. with the many variables inherent in these units we the purchasers determine the final output (thrust) of these units according to how it is utilized.
so then, what prompted you to purchase the particular unit you have? Size? weight? diameter? Info from someone else? guesstimate? or just plain luck? or All the above? |
Thrust depends on a lot of electrical and mechanical parameters, however, the manufacturer has no influence/say in the power system, and it is not their field of knowledge.
Specifying thrust as function of rpm hides/seperates those parameters nicely, just like with propellors. You don't specify an AC's cooling capacity by its wire diameter or the size of the holes in the mesh. Having said that, I don't know why manufacturers don't specify EDF thrust/rpm numbers. Nah, for Chinese manufacturers it's probabably a simple explanation: the user is the tester. Vriendelijke groeten ;) en wees voorzichtig Ron • Without a watt-meter you are in the dark ... until something starts to glow • • e-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC • |
(Post 12629659)
so then, what prompted you to purchase the particular unit you have? Size? weight? diameter? Info from someone else? guesstimate? or just plain luck? or All the above? Only few days ago started on 4 engine EDF jet build, the first thing I wanted to find out aprx. thrust of each unit, to give me an idea about the size of the air frame to cut out of Depron base. I was rather conservative, making up the smaller frame before power units arrived. Rather have more juice than not enough. Can't wait to hook it up to see what it pulls on the ground combined as "quadrosonic", https://cimg1.ibsrv.net/gimg/www.rcu...69da50ad62.jpg First check run gives me some idea about the thrust. https://cimg1.ibsrv.net/gimg/www.rcu...e797e68421.jpg Circa-200 hour job in progress. but after the first quick check run to see the current draw, I think I could have gone lot bigger. |
Originally Posted by ron_van_sommeren
(Post 12629803)
| All times are GMT -8. The time now is 08:10 AM. |
