RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   MICROJET HELP (https://www.rcuniverse.com/forum/electric-rc-jets-198/1587619-microjet-help.html)
AWDEVO8 03-03-2004 07:01 PM
MICROJET HELP
HELLO, I RECENTLY TRIED TO FLY MY MICROJET. IT HAS THE STOCK MOTOR AND A 9.6V 8 CELL BATTERY . I through it in the air and it took off like a bat out of hell. The only problem is that it started losing altitude immediately! once it got into "ground effect" , it just stayed there at about 3 ft of the ground. IT WOULDNT CLIMB OUT AT ALL!!! I DONT GET IT BECAUSE IT WAS SCREAMING AT OVER 60 MPH NO DOUBT!! ANYBODY HAD THIS HAPPEN? ANY LNOWLEDGE OF THE PROBLEM IS GREATLY WELCOMED! THANKS
SJN 03-04-2004 07:47 AM
RE: MICROJET HELP
1 Attachment(s)
have you installed the prop the right way ?
the writing on the gunther prop should face away from the plane
Which cells and how many are you using ?
AWDEVO8 03-04-2004 03:06 PM
RE: MICROJET HELP
I'm pretty sure the prop is on the right way. it uts out a tremendous amount of thrust. I'm using a 9.6 volt ni-cd batt. I believe they are aa size at 1.2 volts a piece.its a stick pack and it needs to be slid way back to have the correct center of gravity. maybe its too nose heavy?
SJN 03-04-2004 03:23 PM
RE: MICROJET HELP
well, it is quite sensitive to CG
It should fly fine when it balances EXACTLY on the small bumps :-)
When you launch, and if you hold full up elevator, it can be enough to brake, and slow down the plane so much that it never gets up to flying speed.
I use 8 Kan 1050 cells that weigh 170grams a pack
What are you using ?
AWDEVO8 03-04-2004 04:10 PM
RE: MICROJET HELP
I'm pretty sure they are sanyos 8 cell at 800mah? its not here with me, i'm at work but i will check it out tonight
cybermatrix 05-19-2004 04:02 PM
RE: MICROJET HELP
i've the same problem
it won't stay in the air it drops very fast
i got it as a multiplex package
with motor + servo's + speed controller + battery
so it it should fly with the orginal stuff
but it won't
and it's pretty messed up already:eek:
AWDEVO8 05-31-2004 12:52 AM
RE: MICROJET HELP
Its been awhile sinnce I posted on theis micro jet. I moved and tore the right elevon from the factory hinge. You knoe that skinny part that acts like a hinge along the back of the wing. Any Ideas on how to fix it?
Cactus. 06-05-2004 05:12 AM
RE: MICROJET HELP
tape will fix the elevon..
i bet your holding full up trying to make it climb. mines on ten cells but with all flying wings you have to let it drop a little to build up speed, once it's "on the step" you can get flying. on 10 cells i can just about self launch.
a little bit of up on launch ( 5mm ) helps but let off soon after.
hexonxonx 06-09-2004 07:55 AM
RE: MICROJET HELP
man it has to be on the verge of stall from over controll , get ahold of me i,ll drive on up and fly it for ya once then your on your own. fix it for ya too.
