RE: SUPER SNIPER
hey Joe,
I'm using a mega 2t on a 3s2p 4300 Tanic lipo pack.. it goes in under the canopy and as far back toward the intake ducts as I can get it (almost rides between them ).. it rides on it's side with velcro on the bottom of the fuse ,and some straps my cg is around 82-85 mm as opposed to the recommended 90 mm. I can live with it as I 'd rather not add dead weight . nice flyer ! good luck ~ |
RE: SUPER SNIPER
hi swampy. thanx for the info i feel a bit more confident at trying it now. it's along the same lines as your own. 90mm-85mm i think its close enough. im useing the same motor as you i think ....... what do you think of the performance....................................... .......
RE: SUPER SNIPER
Just watched a vid on these things, looks like they move good, anyone radar one of them? Whats the fastest engine setup cost approx?
Looks like alot of fun! |
RE: SUPER SNIPER
1 Attachment(s)
Hey Guys,
Just working on my Sniper and getting near the end. Can hardly wait to fly her. I thought I would pass on this building tip I found while trying to make the wing servos look a little more elegant. I am using Hitec HS-56 in each wing panel for the ailerons. As you know they stick out below the surface level of the wing. Just before tossing out a used Old Spice anti-persperant container, I noticed the nice shape of the cap. I cut the cap roughly in half and then sanded it down to the right height just so it covered over the servos. Pictures attached pretty much show the result. I think it looks cool, streamlined and didn't cost a cent. :p Cheers, Randy Smith, Calgary, AB BTW, I'm using Mega 16/15/2, TP3S2P 4200, Phoenix-45, 480 mini fan.[img][/img] |
RE: SUPER SNIPER
1 Attachment(s)
You will love the plane. Here Ã*s a nice video of mine.
Best regards Rico Nice idea with the wings I used very cheap servo covers for sailplanes. http://www.rcuniverse.com/mvp/mvpPosts.cfm |
RE: SUPER SNIPER
RE: SUPER SNIPER
RE: SUPER SNIPER
Has anyone thought of putting very small turbine on the super sniper by HET RC
Wild thought but im just crazy like that. Hey does anyone know where to find a 65mm in diameter turbine like that would fit this jet cheep hopefully. Please post answer Thanks |
RE: SUPER SNIPER
Here are a couple links to micro turbines ... take a look and see what is there and note many are still in development. Also, you may wish to check in the Turbine forum as this EDF forum is less likely to have much in the way of response.
http://www.artesjet.com/jf-35_nano-bee.htm Toki Micro Turbine still in development...no website http://www.jethangar.com/ These guys have a 7lb thrust Wren 44 mini turbine that may work http://www.m-dot.com/page8.html http://www.lambert-modellturbinen.de/index.html http://jetjoe.com/cp_detail.php?id=6...cpath=&catid=0 Hope this helps, Carl |
RE: SUPER SNIPER
Thanks but Ive aready found those sites by searching. But still waiting on respose by emailing a couple of them. Have you seen the super sniper by HET RC do you think this model will handle one of these small turbines
Thanks |
I would like to know who sales this Super Sniper xl 90mm jet ?
Thanks |
Fan Jets USA or HET , just got one myself. give Matt a call at Fan Jets USA
1 Attachment(s)
that sniper on 4s with 3600-3800kv, ( check out mega motors edf16 or 16/25/1.5r ) will really make it move out better then 3s
heres a pic of my phoenix. its a sporty like the sniper but way slicker and much faster |
good looking plane , got more pics/specs ? who makes it ?
Do you have the instructions for this plane?
I came by 2 of them at a swap show and there are no instructions. Thanks, Chuck |
| All times are GMT -8. The time now is 07:28 AM. |
