RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   lipos (https://www.rcuniverse.com/forum/electric-rc-jets-198/3778051-lipos.html)
JAMES SMITH 01-15-2006 03:33 PM
lipos
I have a hacker B40 11s in a Skyray,what would be the best pack to run with unit ?
4S1P 2500,3100,Etc and I would like a run time of at least 7 minutes
Thank You
James Smith
BeanerECMO 01-15-2006 03:44 PM
RE: lipos
Go to Jet Hangar Hobbies, and Larry can show you the way.
JAMES SMITH 01-15-2006 05:04 PM
RE: lipos
I am looking for a general answer,I know larry wolfe,iI have a wren 54 turbine from him
CTulanko 01-17-2006 03:54 PM
RE: lipos
James,
I am going to assume you mean a Minifan 480 sized Skyray. A 3S1P Kokam 3200 pack should give you around 375-400 watts of power with a run time of around 6-7 minutes, or more with throttle management. If you use the motor with a 4S pack, the Minifan 480 will produce too much load and would most likely burn up the Hacker B40-11S motor.
With the 3S Lipo, make sure you have a pack that can supply at least 45 amps or more.
Carl
