RCU Forums
-   Electric RC Jets (https://www.rcuniverse.com/forum/electric-rc-jets-198/)
-   -   Phase 3 Ef-16 help (https://www.rcuniverse.com/forum/electric-rc-jets-198/6693921-phase-3-ef-16-help.html)
skyracer068 01-02-2008 09:16 PM
RE: Phase 3 Ef-16 help
1 Attachment(s)
Use the stock motor with a different speed control. I am running a Castle Creation 35 with a Thunder Power 2200 mah V2 battery and am in the 90 mph range. I never leave home with out this model. Good luck.
skyracer068 01-02-2008 09:18 PM
Only the pigeons complain at my local park.
f86 01-02-2008 09:53 PM
Did you use stock set up or did you modify????????????????
skyracer068 01-03-2008 02:54 PM
I used the stock motor and fan unit but am running a Castle Creations 35 amp speed control. The stock speed control burnt up when I started running a Thunder Power 2200 mah V2 battery. With this set up, you will draw 28 amps continuious with 275 watts for 7 minutes. Good luck.
P. Richards 01-03-2008 05:17 PM
Excellent tip I just purchased 5 2200 Thunder Power Extreme V2 packs for the f-16 and My Stryker.
P. Richards aka SwatTeam
tuan lam 01-04-2008 12:45 AM
16--
kingpin112 07-15-2008 04:50 AM
I have some 3S-2250mA 18C lipos, weight 191gr. Can i use this in a stock setup or are they too heavy?
