Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
 my 1st loop in slow stick >
Electric Training If you are new to electric learn more about them here or ask questions.
Old 04-18-2004 | 09:11 PM
Default my 1st loop in slow stick
well start off wind was low nice to fly in.i had 15 min or better flight times this was my 4 th time flying rc planes i did the loop a little low 3 feet from ground it came to. but i had 3 flights and no broken props .i have to use the 1280 prop and it works fine . i want to move up to a fighter now whats the best one going not to hard .im makeing video of my flights soon . just wont to say how fun the SS is its the best way to jump in rc buy your self slow stick was 3rd plane p51 never did good 10 feet crash and e-starter i crashed in tree on take off never got to fly it .so i think im rdy for a fighter maybe jet tks if any got some tips it will help tks
Old 04-20-2004 | 07:07 AM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: my 1st loop in slow stick
You can roll the Slow Stick too. Make sure you have as much rudder throw as possible, then get up pretty high so you can recover if necessary. I don't want the dead carcass of an airplane on my conscience
Start out by bringing the nose up slightly, then give it full left rudder. As the plane goes inverted, jam in some down elevator, and the plane will roll right over. That's DOWN elevator, forward on the right stick, just so there's no confusion.
Aborting the maneuver is simple if you're high enough. Let go of the rudder and pull back gently on the elevator stick. Depending on where you are in the roll, you'll either end up flying upright and level, or you'll end up in a tight turn.
Old 04-20-2004 | 11:32 PM
sweet tks ill try it slow stick is nice plane to learn on haveing so much fun with it
