Electric Training If you are new to electric learn more about them here or ask questions.
antenna length
Old 09-06-2004 | 09:53 AM
Default antenna length
how long should the antenna from your reciever be?
Old 09-06-2004 | 02:32 PM
sprintdawg007's Avatar
Default RE: antenna length
we need more info....does yours look short or something?
Old 09-06-2004 | 04:40 PM
the info at the reciever tells u to keep it as it is. i have two pico tiger moth the one that has the antenna shortened has a shorter range than the one that has the antenna kept the way it is.
Old 09-06-2004 | 05:12 PM
Matt Kirsch's Avatar
My Feedback: (21)
The exact length is not crucial. Typical receivers have antennas ranging between 36" and one meter long.
Some single-conversion receivers, like GWS receivers, have 18"-20" antennas, and the instructions with some of these tell you to cut the antenna if you're having severe interference problems. A warning, though: DON'T CUT YOUR ANTENNA UNLESS THE INSTRUCTIONS RECOMMEND IT. What's happening is the receiver is getting TOO MUCH signal, and is being swamped. Cutting the antenna reduces the intensity of the signal the receiver is receiving.
Old 09-06-2004 | 09:05 PM
my antenna got cut by the prop while taxiing. i replaced it with a long wire of same diameter. it is like 5' should i cut it down to about 3'
its GWS
Old 09-09-2004 | 10:17 PM
aeajr's Avatar
If you are flying a 72 MHZ radio system, your antenna should be between 36 and 41 inches long. much over or under and the receiver's performance will suffer.
