how to select motor, etc.
FL
take a look here to give you some idea of costs involved, Hobby Lobby's done quite a few conversions and give you a nice break down of what's needed per plane.
Just click on one of the photos for a break down on each bird.
http://www.hobby-lobby.com/glowtoelec.htm
So, you're looking for a power system around 1150-1200 watts. This will give you vertical power on a 60 size plane. If you have trouble selecting a specific motor/battery/esc/prop from hobby lobby, go to their model power system matching program, and they will customize a power system for your specific plane.
About 800 watts would be minimum for your goals and about 1200 would probably be right about on the money. You can always go higher.
Figure 20 volt pack and about 60 amps using a 6S lipo pakc for a 1200 watt set-up. Or a 30 volt pack ( 8S ) and 40 amps. Both would work, just a matter of what the motor calls for.
For 10 minutes all out figure an 8 Ah or 8000 mAh pack, asssuming you are running all out all the time. With a little throttle management you could do it with a 6000 mAh pack.
You could also look at A123 cells for a plane of that size. High discharge and fast charge make them a good fit or planes like that.
The combo 46 would be your budget package. The Combo 60 sounds more like what you are looking for.
http://www.maxxprod.com/mpi/mpi-264.html
