Go Back  RCU Forums > Electric Aircraft Universe > Electric Training
 Need help with electronics. >
Electric Training If you are new to electric learn more about them here or ask questions.
Old 05-07-2009 | 09:30 PM
Default Need help with electronics.
Well I bought this plane last night for my second plane.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJTK1&P=0
I need someone to help me configre a good electronic setup for it.
I need
Servos
Speed Controller
Battery
Charger
And the receiver for a 4 channel radio which I have but need the plug in thing for micro servos.
Thanks James
Old 05-09-2009 | 09:30 AM
Default RE: Need help with electronics.
Hmm... second plane... "for intermediate and advanced flyers".
I'd visit www.lightflightrc.com - a Suppo 2212/13 (~1000Kv) would spin the recommended 10x3.8 prop well. Dave has combo ESCs... 20A would be fine. It seems you need reasonably strong servos - 15oz/inch... I'm not sure where to send you for those.
Try 2DogRC.com... they have 22oz/inch Bluebird 9g servos, masses of battery packs, and a Bantam Charger
If you want one-stop shopping 2DogRC has excellent motors (http://www.2dogrc.com/ecommerce/os/c...ze-p-2027.html) and they must have ESC's too.
Old 05-09-2009 | 10:54 PM
What was your first plane? What charger/batteries do you have from that plane?
What radio do you have now? I don't know what plug in thing you are talking about for micro servos, but all except the very smallest servos (which that plane doesn't need) use basically the same standard plug. Any micro servo should do, an E-flite S75 or Hitec HS-55 should do fine and are around $10-15 each.
If you are going to use the included brushed motor the speed control should be fairly cheap. All you need is a basic, brushed ESC.
For size and weight you will be best off with a Li-po pack around 500-800 mAh. I had almost that exact plane and I flew it outside and liked the extra flight time so I flew it with 800 mAh and 910 mAh batteries. A bit heavier than it recommends, but I wasn't going for extreme 3D so it worked fine for me. However, I didn't use the included motor, so I can't say for sure what is best for a balance of run-time and weight with the included motor.
Old 05-11-2009 | 03:32 PM
-pkh-'s Avatar
I doubt it will fly very well with that stock brushed motor. Get yourself a brushless motor & ESC for it.
