slow-stick spec
does anyone know where I can find specifications for the slow-stick ?
Specifically, I'm after the amount of dihedral (in inches etc) and the width of the aluminium fuselage thanks Digsy |
RE: slow-stick spec
Just measured mine for you - the fuselage is 10mm square section (11/32" in confusing US units), and, as built, mine has 17cm (6.5") OVERALL dihedral measured to the tip of the trailing edge (i.e. if the wing was mounted in position, the two trailing edge tips would each be 8.5cm (3.25") above the horizontal).
Hope this helps, Cheers, Phil |
RE: slow-stick spec
Here ya go...if ya have anymore GWS questions on specs. ;)
[link=http://www.gws.com.tw/english/product/airfly/airplane.htm]GWS website[/link] Brian |
| All times are GMT -8. The time now is 10:31 AM. |
