need help
bought a 27mh reciever for a small plane my grandson has. this reciever has 2 channels, but the connections for servos are 2prong. all the servos i have or have seen have three wires. any one know were you can find servos of this type or can the three wire be used somehow.
RE: need help
Proprietary gear is bad for just that reason. You would have to find what the receiver was made for and buy all the stuff from that plane. 3 wire servos will not work with it.
RE: need help
thanks packyj, i supected as much, but have a lot of survos i would like to use.
RE: need help
Your 3 wire servos are probably for 72 mhz systems. Very very few people in North America buy 27 mhz components to put together a radio system. The 27 mhz systems are primarly RTF packages. Parts, such as what you bought are usually specific to a given plane which has those types of servos.
Where did you buy this receiver? Maybe you can exchange it. |
| All times are GMT -8. The time now is 03:29 PM. |
