broken wing what to use
I have a J3 cup foamie and brok the wing at fuse,should I use eproxy of foam ca anf tape to repair.
wattmeter |
RE: broken wing what to use
My personal choice would be epoxy, though if it is an extremely clean break, CA might work. Epoxy will do a better job if the break is irregular. - Jeff
Thank jeff
I have never worked aroud foam before and was not surt what to use. Again Thanks Bill |
Hi Wattmeter,</p> For a broken wing repair, you should include some sort of reinforcement. A carbon fiber rod is best, but you can also use a wooden skewer, a plastic rod, etc. Basically, anything that is light but rigid to keep the wing from flexing at the break.</p> |
| All times are GMT -8. The time now is 07:29 PM. |
