RCU Forums
-   Electric Training (https://www.rcuniverse.com/forum/electric-training-102/)
-   -   Will These Batteries Work?? (https://www.rcuniverse.com/forum/electric-training-102/8914706-will-these-batteries-work.html)
Canadiver 07-07-2009 08:31 PM
New plane being ordered tonight ( http://www.bananahobby.com/1865.html )
and i have several of these lying around ( http://www.thesource.ca/estore/Produ...roduct=2300321 )
Will they work? if not, is it possible to use a lipo battery with the stock setup? any reccomendations are greatly appreciated. Thanks!!
Casey
wattmeter 07-07-2009 08:54 PM
RE: Will These Batteries Work??
Read what the planes needs, an 8.4 volt 1000 mAh Ni-MH battery not 9.5v! if you try to use the 9.5v you will have to reduce the voltage.
wattmeter
Boomerang1 07-08-2009 06:24 AM
The specs list an optional lipo battery 'to achieve better performance & longer flight time.'
A 2 cell lipo is only 7.4 volts which will mean lower performance, not 'better' so they must mean a 3 cell battery (11.1 volt).
Your battery should be fine at 9.5 volts. - John.
