Electrics to Glow ConversionsAre you converting an electric airplane to glow and need help? Have you already converted an airplane and you want to show it off and give some tips? This is your forum. Enjoy.
If the firewall is thick enough you can cut,dremel/route out the foam and epoxy in a piece of aircraft plywood . Then you can attach the mount with screws.
If the firewall is thin you can use plastic fender washers front and back with bolts and nuts.
