How to control throttle without changing receiver
Can you map the left forward and back stick on a programmable transmitter to a servo output to control athrottle ring orlever, or do you have to put in a different type of receiver.imtalking about when the receiver has a built-in esc
I've seen, and used, several different types of programmable transmitters and the first 4 channels in all of them were fixed. I would think, however, than an OpenTX transmitter might be programmed to put the throttle stick on any channel but that would be at the processor level, not at the user level. But the more important question is what channel your receiver's built-in ESC is on? With that answer you might also be able to use a mix to map your throttle to the ESC.
