Pusher propellers
Pusher propellers
I have a Falcon 120 which has an O.S. 120 engine in pusher configuration, the correct prop for this engine is a 16x8 pusher prop. However with this prop fitted I would only be cutting the grass not flying the plane.
Can anyone out there tell me if a 4 blade prop is available commercially and what size do I need, if not can anyone tell me what size 2 bladed props do i need so that I can fabricate a 4 blade prop from them.
As these props are very difficult to obtain here in the U.K any help would be appreciated, unfortunately O.S. do not seem to have a help or advice section on their site.[&:]
RE: Pusher propellers
Thanks for your help, am awaiting a delivery from Joe at Zinger direct.
When they finally arrive we should be nearly airbound
